unfortunately, Djay 2 has stopped
Cant get it to work, tried reinstalling numerous times. Device: S6 edge
Hey Martin,
thank you very much for contacting us!
To help you out with this problem I need some additional infos:
* What exact djay version are you using ?
* Does djay shut down after some special actions ?
* If yes, would it be possible to tell me the steps to reproduce this issue.
Thank you in advance,
Alex
Hi Martin,
thank you for your reply,
can you please contact our support via support@algoriddim.com and please tell them where you stored the djay application on your device. Thank you.
Also we are sorry for the inconvenience and the problems you had to experience.
Djay version 2.2.2
I open the app, and get the djay loading screen, then i get the error message “unfortunately djay 2 has stopped” and the phone goes back to the launcher.
