Update Spotify Library on Ipad
Spotify library update
If I add or move a song in Spotify to a playlist is there a way to get the Spotify library to update and show the change?
So far the only way I can see is to close the app and reopen
thank you for your post.
Could you tell us which djay version you are using?
Thank you in advance.
Hi Michael Talbot,
refreshing your Spotify playlists is not possible on the flight, you have to close the application for refreshing the data.
Djay 2
Michael
Ok Thanks
