Suggestion New setting to add to the current crossfader curve settings “Thru” to essentially allow users to disable the cross fader if required.
I second this suggestion. Would love to be able to disable the cross fader using a thru mode type curve.
Would definitely be nice to have that option
This would be similar to the “thru” switch on Pioneer controller and would definitely be a welcome feature.
This is exactly what made me think of it
I totally agree with you. Having the option to disable the crossfader should be a developer priority.
