Has anyone else notice that your cue points are not showing up on DDJ-WeGo after you’ve upgrade the controller to v.1.09. I guess I should say there not highlighted on the controller
Hi Terre,
Thanks for contacting us.
Never heard of this issue before. Are the cue points still visible in djay?
If possible, can you please make a video recording showing the issue?
Thanks for the reply.
A video recording of the problem would be really helpful. Is there any chance you can make one?
Yes they are still visible. But if I press on a cue point again it will just set a new one (not even erasing the old one)
I doubt that. Don’t have supporting software.
