Since the last update I’ve been having an issue with Spotify songs via djay pro 2.0.9 version when I choose a song it loads fully and in the song info section you can see it’s fully loaded however sometimes the song stops without warning and it looks like the song is not loaded correctly I have attached a few examples.
Thanks for the info I actually do have an 8gb ram and 400gb HD I have always used this mac with djay 2 and Djay pro never had this issue only recently after this new update it started happening.
You have very low memory space two run djay pro 2 you need 8gb of ram 400gb hard drive you need to do a hard disc clean up plus your screen resolution is too large reduce the retina display to normal not high…then open spotify account on laptop not on djay and change setting to
normal (recomended) for low speed WiFi then. See if it works
