USB 3.0 vs 3.1/3.2
Does anyone know if connecting DJay to an iPad Pro through a “better” version of USB helps?
So, basically, would I notice a difference in performance if I use a 3.2 cable vs a 3.0?
I know theoretically it could be better, but in reality does DJay even need the extra data transfer speed?
EDIT: so actually I’m wondering about when I use a USB Hub to connect to my iPad Pro.
Does it matter if the hub is rated as USB 3.0 vs 3.1 or 3.2?
It only matters when transferring gigabytes of files to your iPad Pro. MIDI and audio performance will be the same on USB 2.0 and 3.0++.
Thanks for taking the time to help me out!
You beat me to it @Michael_Wisniewski! I was going to say the same. Thanks for the answer as usual.
