Use Audioshake Indie model Neural Mix Pro
I asked Audioshake if the model in Neural Mix Pro is the same as the one on Audioshake Indie.
Here’s what they said:
This is pretty unfortunate for me because the Audioshake Indie website is expensive and unusable, especially when uploading copyrighted material, which most producers and DJs want stems from.
Please use the Audioshake Indie model for stem splitting in the Neural Mix Pro app.
As you can see in their reply, that might not be the easiest or most helpful option unless you have a really powerful setup.
They could implement a cloud-based solution for the more advanced Audioshake model, while still keeping the option to run the on-device lightweight model.
Ah! I’m sorry, I was thinking djay here.
Thanks for the suggestion @Nguy_n_Nam. I’ll share this with our devs for consideration.
