Use iPad as Scratch
It would be cool, if you could use the iPad as a touch screen for the Mac version and if you could listen to the music using the iPhone so you can have the earplug output on the Phone, the scratching on the iPad, and iTunes and the main software on the Mac. Or just make the iPhone Remote available for iPad so you can use your iPad as are remote. This would also be great.
