Having lost my iTunes a fair few times, from my laptop crashing I can no longer be bothered to rip my CDs back on to iTunes and have now turned to using spotify premium Which I find a lot easy to use then iTunes it’s self.
However haveing a big interest to this app, I don’t believe it let’s you run spotify through this app and I though it would be a great addition to add this feature to it.
i think this would be made possible easiest by having a premium spotify account where you have an offline mode where the files are actually downloaded and stored locally, but im sure it would also be possible with a streaming library, whether its a library choice in djay app or algoriddim develop a spotify app for use within spotify itself!? either way make it so algoriddim!!!
It would be SO good if it were possible to select iTunes library & Spotify (streaming) libraries & mix between the two - is there any plan for this to happen ?
Yes pleeeeeeaaassse integrate Spotify. If you make it accessible only for premium users Spotify could have an interest in a collaboration. Since I have Spotify I basically don’t use iTunes at all anymore. Hence I don’t use your djay app also, although i like it a lot. If Spotify will put a dj app on the market by themselves I will switch to that. But since you created a fine app it only need the integration…
