Is there anything in the roadmap for custom transitions?
Maybe having something like a edit button next to transitions, when you click it, the app shows a view with different customizable effects that can be saved as layers.
For example,
One layer could be a reverb that gets wetter as the transition completes.
Another layer could be an echo out…
Another layer could be a polyphonic echo…
And so on.
It would also be nice to be able to customize the volume curves so that we can control how one song mixes into the other.
Hi @Martin_Garcia, welcome to the Community! Thanks for the suggestion. Are you familiar with the Crossfader FX? We have quite a few options to choose from in there. Please let me know if this is what you’re looking for or not. Thanks!
Yes I’m familiar with Crossfader FX, and I use it quite a lot, specially in the Automatic Mix mode on Android, but lately I’ve been noticing that some of those transitions do not blend song smoothly, either some effects take to long to mix in the incoming dong or the fading curves dont work well… or they are also becoming monotonous.
It would be great if we had the ability to create our own saved preset transitions.
