Using 2x Denon DN-SC2000 for 4 channel mixing
Hi I bought 2x Denon DN-SC2000 Midi controllers which work great with Djay pro natively in a 2 channel mixing scenario.
But as each controller has the ability to switch between 2 decks, how can I set up Djay Pro so the first controller controls Decks 1 & 2 and the second controller mixes decks 3 & 4?
Currently both controllers can mix/switch between decks 1 & 2 only.
Hi Harrison Logan,
you need to remap one of the controllers so he is working with deck 3 and 4.
If you need help doing so please contact us via support@algoriddim.com.
Cheers,Lukas E.
