i wanna use any of 6 chosen effects on any decks (when using with iphone/ipad with Wego4)
the same ability is on NI Traktor software.
Hey there,
thank you for your post. So you want to be able to use up to 6 effects on any deck? In which scenario do you feel like 3 are not enough?
I think its about many scenarios, as like as in the case, when 3 effects works as a beat cycling effects, and another 3 effects is about frequencies effects. not coincidentally, this opportunity is in the NI traktor
