using a playlist
How do you use a playlist? or can you at all?
Hi Michael,
Tap the AUTOMIX button, select Automix Queue and click on the “+” button to add songs. After adding songs, you can rearrange the songs by tapping “EDIT” and then drag the songs to the desired position. There is only one queue for both decks and the song will always be loaded on the currently inactive deck.
let me re-phrase a queing list I want to dynamically add and remove as needed. I am talking maybe 5 songs at the most in either turntable que.
