I’m looking for an affordable DVS mixer, and Akai AMX keeps coming into view. Unfortunately, this is not a full standalone mixer, which can also play normal records. Serato offers here the possibility to also loop through the analog audio signal of the turntable. But does that also work with Djay Pro AI?
You can use GarageBand for this if you just want to listen to vinyl. You could map the controller to it too.
Or try out djplayer pro it has the audio thru feature and dvs. The amx is supported natively by the app.
Or get the Numark Scratch mixer. This would be the best option.
