Hi guys so I have a bit if a tricky one. Any help really appreciated in advance. Will do my best to explain.
I’m travelling next month so am using my iPad pro and reloop buddy as very small and easy to take with me.
However the sound/soundcard coming from the buddy isn’t very good when playing on large systems so I want to buy an audio interface. I tried with my bose T8s mixer using a usb hub to connect it to the iPad but couldn’t work out how to cue up tracks separately.
I think I may need to buy a separate audio interface.
Do I route audio from the reloop buddy RCA outs going into the audio interface and cue up using the headphones out on the buddy or will this just be the same audio quality? I.E. would the audio be processed in the reloop or in the interface? Would the quality be that of the buddy or interface that I purchase.? If the audio is that of the interface then I assume I can just use my Bose T8s mixer and route the audio via analogue cables and cue using the buddy.
And if I route audio through usb (if the analogue audio route doesn’t help above) how do I actually manage to cue as the headphones socket on the buddy won’t work as audio is being transferred via USB to the interface.
I hope this makes sense!!
Thanks so much!
Ben
