I like to prep on my mac at home with the big screens and then play on my macbook. On rekordbox this was easy as I was able to store the database on my external SSD. In djay sadly that isn’t an option so I needed a workaround.
What seems to work is once I have finished my prep, I then copy the djay media library out of the music folder, stick it on the SSD and then when I plug that into my macbook, drag it off the SSD and into the music folder. It’s a bit of a faff, but it works.
HOWEVER
In order for this to be successful, you NEED to switch off iCloud sync for djay. I had situations where I had set cues and loops and then when I loaded those tracks on my macbook, the cues and loops had GONE and it was doing my head in until I realised that djay sync’s with iCloud and that was messing it all up. I turned off iCloud sync and now everything works in harmony!
I just wish now that djay supported storage of the media library and settings on an external drive, that would be lovely.
