Question for any users of the XP2…How does the fx work on the xp2 since we can’t use the slide fx? Do we have to use the hold button and then press the number fx for it to stick like we’re using paddles? Or do we have to map those buttons to function that way? Thanks for any help. Couldn’t find anything on it. On the fence about copping it ![]()
Hi @DJ_A_Diffrance, on the XP2 the FX Level Strips are permanently set to Hold Mode.
Thanks!!!
I wish i knew about this kit before I got the novation mini. So much easier.
You’re welcome @DJ_A_Diffrance
