Hi, I use the DJay Pro on my iPad along with the Reloop Beatpad 2 DJ Controller and for some reason, I cannot figure out how to activate and use sample buttons on the right side of the controller. Any suggestions?
Hi @SleepyDon,
Thanks for posting in our Community.
So that we can better assist you, could you please provide the following information:
- Which device do you have?
- Which OS version is running on your device?
- Which djay version are you using? (If you are using an iOS/ Android device, please open the djay settings and scroll down to determine the version number.)
- Have you added your own samples to the sampler? FAQ on how to do so.
Hope to hear from you again.
Cheers, G
I’m using the Reloop Beatpad 2 DJ Controller with an iPad version 15.1 with DJay Pro AI 3.8.2. Yes, I’ve added my own samples but I can only activate them from the left side of my controller, not the right.
Hi @SleepyDon,
Has this recently started happening?
Please note that in order to access the Sampler you need to press SHIFT + HOT CUE (on each deck).
Cheers, G
I think that did the trick. Thanks for your help with this.
