Using Serato Crates With DJay Pro on iPad Pro
Hello Community!
I want to use my iPad Pro (4th Gen) with DJ Pro and external hard drive consisting of Serato crates. How would I go about using Serato crates and external drive with DJ Pro playlists?
Please answer the question using steps.
Best,
Michael
@DJMikeDottin you need to convert your Serato library database to a djay Pro AI library database using software like DJ Conversion Utility. This will convert your crates/playlists and hot cues over to djay’s system.
Thanks so much, Slak_Jaw!
You’re welcome @DJMikeDottin
Hello,
Can you do this for the iPad or only Mac?
@E_Flem you need a Mac to run the DJCU software, but once you convert the Serato library over to the djay library on Mac you can copy that over to iPad.
@E_Flem first you have to convert your Serato library to Rekordbox then from Rekordbox to djay Pro AI.
