using smart crates in dj pro windows version
can you use smart playlist in the dj pro windows version, if so how do you get to the smart playlist rules
  1. There are no smart playlists in djay Pro Windows, only static playlists.
  2. To get smart playlists, use iTunes / Apple Music to manage your library.
  3. FWIW - even on the Mac and iOS, it’s still preferable to use iTunes for smart playlists, so you’re not really missing out on anything.
