How do I reset or get back controll of the EQ’s when I play with deck 3 and deck 4? I’m using Pioneer DDJ SB2 and while mixing it’s easy to forget the EQ’s exact positions. What is the best way to get controll of the EQ’s when changing from for example Deck 1 and then to deck 3?
Ok it seems you always have to return to the same position where the EQ’s were before you made the change and then you can mix them back.
