Just finished a mix using djay version 4.0.6. but now want to use the mic.
I can’t find the mixing table for the mic. How do you use it?
Thanks for any reply!
Regards, Bert
Regards, Bert
Hi Warren, thanks but I noticed this.
But it is a kind of strange that there isn’t a normal slider like the 2 for the turntable. As soon as you switch off the mic and switch it back on the level is set to zero!
I have the microphone all squared away, but when I turn it off and then turn it back on, the amount of sound being outputted through the speakers resets to no volume. How do I fix that?
