Day pro AI version 5.1
Sonoma 14.3 on M1 Mac Studio
Cannot export playlists to TIDAL from the History list. Get this message:
The data couldn’t be read because it isn’t in the correct format.
Any help?
Thanks,
Mike
Any help?
Thanks,
Mike
I’m getting this message too but it’s only when I’m trying to add songs to playlists (MacBook Pro, latest version of djay and latest iOS update
So, I have realized that the playlist IS actually exported to TIDAL effectively. However, it gives this error message.
Mike
Thanks for letting us know about this. As you noted the playlist should still be successfully exported despite the error being shown. We’ll fix the error display with the next update.
Hi @mainemike, this should be fixed in the latest 5.1.1 version which is available now.
