Vertical Neural Mix Volumes on Desktop OS like on iOS
Option for iPad layout on Macbook:
big 4 channel Vertical Neural Mix sliders on MacOs / Desktop like on iOS.
Currently Macbook layout for stems is small and takes up less space than on iPad. Small horizontal 4 channel stems are hard to notice which channels are off or on in 4 deck view.
The iPad vertical stem sliders make it easy to see whats on and off in 4 deck mode.
Please make an option for iPad layout on Macbook.
Thanks for the suggestion @dancelove. I have forwarded this to the dev team for consideration.
