I’ve a suggestion to give because lots of Djs like to see the waveform and the beats in the vertical way, this because the come bigger than in the horizontal way.
the problem is that if i select 2 decks the library is too invasive and i can see just 2 beats that is not enough for mixing.
if i select 4 decks is perfect size but lots of other information are lost like the position of the tempo slide and the tempo lock.
on my personal opinion the library should disappear when you don’t need it and leave the screen only for the waveform .
Thank you Gian Luca
