Hi again @Sanjeevan, can you please confirm if you have an active djay Pro subscription? If so, you can access the view shown in your second image by using Pro Mode.
My current Ipad works just fine, but Im looking at upgrading my Ipad, what do you think is the best option shall i go for the latest Air m3, or do you think would need to go for the Ipad Pro.
You’re welcome @Sanjeevan. The M3 iPad Air will run djay very well. You don’t need to go for the iPad Pro. Personally, I always approach hardware upgrading by setting myself a budget and then purchasing the most modern and highest spec’d device within that budget. This usually means that I can get the maximum life out of that device before I need to upgrade again. I hope that helps.
Will there be any customisation of personal layout in the future ?
As I use an external mixer and k2s I would love to have the beatgrids under the wave forms in the 4 corners in pro mode instead of them being in the middle under one another and do away with the eq,bpm and other clutter that I don’t need as I know what my midi maps are assigned to on my k2s. Just a bit more of a professional feel and appearance and personal preference.
Thanks.
Hi @Daveworzel, if you have a macOS or Windows device, there is a bit more control over the onscreen layout. Also, there’s an existing Suggestion topic below for more layout customization:
