Since several months djay has a real impact on the energy consumption of my MacBook Pro 15" touchbar (default configuration), even if the app is only open in background without playing sound.
Moreover, my Mac becomes hot in few minutes.
Hey dan,
thank you for your post.
Are you using djay a lot without charging your Mac?
Yes, maybe 90% of the time.
Last year with my old macbook I hadn’t encountered any problem until an upgrade (don’t remember the version).
Today I lose maybe 2% per min.
Even Xcode with a bunch of softwares and tabs in safari… produce such a loss of energy.
So…?
Are you planing to make an update ?
Thanks for a reply
