Hi people, just purchased a vestax spin 2 and am using with a macbook pro.
I cannot get any output from the main output of the spin 2 and when I check the audio devices in the audio midi setup from utlities it shows zero volume levels for the vestax spin 2 audio out. It will also not allow me to select anything/change the levels.
Can anyone suggest why this is the case? Is this a software failure?
Incidentally, I can get sound to playback by selecting a different output in djay preferences such as built in output (plays ok from the laptop speakers) but if I try to beef that sound up by running the sound from the laptop to a bluetooth speaker or out of the headphone socket of the laptop to another speaker, the cueing goes out between the headphones on the spin 2 and the output, making it impossible to mix.
Ideally, I want the main output on the spin 2 to work!
Help?!
thanks.
