Vestax SPIN: Power adapter vs. USB power
Are there any performance benefits with using a dedicated power supply vs. powering over USB?
Hi Vlad,
There should no noticeable difference, but theoretically, using a power adapter is slightly better.
Regards
Here you go:
https://www.google.es/search?q=vestax…
I bought it at Thomann.
Where can i find the Power supply adapter in a store? and the red and white cables
