will it work?
The Vestax Typhoon is not natively supported by djay Pro, yet.
However, you can map any midi controller yourself, using our MIDI-Learn feature. How to do this? You can’t find a full description here (don’t worry, it’s a really straightforward process):
http://help.algoriddim.com/customer/portal/articles/1902420-configuring-a-midi-controller-using-midi…
