Hi, this may be a dumb question, when I use a VGA adapter to a projector is it full screen whilst allowing me to mix two videos on my iPad at the same time? Or is it a direct mirror of the iPad screen?
Hi James,
You can choose to either output the “main mix” or mirror the app’s screen.
The size of the screen on your display depends on your projector’s resolution though.
