I will play out some *.mp4 clips in the 2 deck configuration.
Both Player show the same:
clip loaded
starting clip - 15 sec. Video then black screen.
Audio will play all the time.
Stop Play and start again - 15 sec. Video then black
Any idea ?
Heiko
Sorry- I use Djay Pro for Mac Vers. 1.2.1
Hi Heiko,
could you tell us if you are referring to the vjay integration of the djay Pro iPad or Mac software?
No worries, could you send us the two exemplary clips via support@algoriddim.com?
That would help us a lot in order to reproduce the issue.
Thank you in advance.
I know this has been a while, but do you recall if you were using the “Match” feature along with automix turned on when this happened?
