What gives? I have a couple dozen video loops, mostly downloaded from motionloops, that will play on iPad and also play in VJay app…but “can’t be loaded” in DJay Pro! I was hoping by buying DJay Pro for iPad I could get rid of using the two different apps, but I guess I can’t.
They are .MOV format. All are about 15 seconds or less. I narrowed it down to either file size or bitrate. I converted them to .MP4 and set a constant bitrate to 10000, which drastically decreases the file size and they seem to open fine in DJay Pro on iPad just fine now.
I am sorry to hear that.
In which format are the loops in, how long are they?
