When using an external display, the video no longer outputs to the selected display (projector in my case) like it used to. Please just re-release the old version of the software in the meantime till you find out what is causing all these new issues! Litterally begging you guys!!!
Hi @Aj_Mernone,
Sorry to hear about your experience with the video not showing on your projector as expected. I’ll be happy to help you out with this. Just to be 100% clear on your current setup and the issue itself, could you please tell me the following:
- What device are you currently using?
- Which OS version is running on your device?
- Which djay version are you using?
- How exactly are you connecting your computer to the external display in question (e.g., cables being used, etc.)?
- Since you said this issue just started, could you please tell me when this started happening (i.e., with which update)?
Thanks again for your patience. I look forward to hearing from you.
