Viewing Decks 3 and 4 in 2-Deck Mode
Hi @Thomas.rowland, I’ve merged your new topic with this existing one. Please use the blue Vote button at the top left of this page to show your support for this suggestion. Thanks!
I will be happy if this could be achieved very soon
I wish I can be able to switch to deck 4 in two-deck mode so it would be easier to use multiple decks in two decks mode like serato dj bcos when I switched to 4 deck mode with neura mix fader and sampler panel sometimes grid editor panel my screen already field with all of those panel i can barely see my library anymore had it been i can switch to deck 4 or 3 while in two deck mode it would have been better tonight and also i wish the sample packs bar can be mappable for easier access to switch from different sample easily…each time i have to click my laptop to change from my name drops to my drum sample pack thanks i will be looking forward to this
Hi @Brown_bkp, please use search before creating new topics. I have merged your new topic with this existing one. Thanks.
Alright thanks about the sample pack in the sampler panel been mappable to for easy access to switch to diffrent sample pack i created
@Brown_bkp
Just a simple button to check off in the settings to use decks 3&4 in 2 deck pro mode instead of using 4 deck mode. I use djay pro on my secondary laptop and 4 deck mode takes most of the screen. Please please please add this. #suggestiobs
Hi @OneCrazyDJ, please use search before creating new topics. I have merged your new topic with this existing one. Thanks.
Would it be possible when you have the two deck mode, you will be able to select which decks instead of the default 1 and 2.
An example where this could be useful: when 2 djs b2b with each their own laptop connected to a mixon pro 8, one dj can use deck 1&3 and the other can use 2&4. But at this moment you only can use it in four deck mode, which clutters the screen much.
Hi @LJsquare82, please use search before creating new topics. I have merged your new topic with this existing one. Thanks!
Ah, I had search, but not with the right keywords. And I see
that I’ve already voted for this topic. Sorry for the double post.
No problem @LJsquare82
in 2-Deckview:
Changing from Deck 1 to 3 or 2 to 4 with the buttons, don´t change the deck view on Djay pro.
The display on the computer stays on deck 1 or 2.
But in Serato in 2 Deck view, the displayed decks on the monitor follows how you choose the decks on the controller.
Can you update this?
Hi @Sneakdiver, I’ve moved your suggestion over to this existing one as I believe they are closely related. Please vote above. Thanks!
Hi! I’ve just bought DJay Pro and I’m very happy with how it feels and looks. In comparison to other software, look is pretty clean.
I would also like to add ability to switch 1/3 and 2/4 decks. I’m using 4 channel 2 deck controllers for DJ. When I enable 4-channel view, there are too many moving points on the screen, I loose focus with my not the best eyes. Also, it’s too heavy to match tracks visually which are not nearby. It’s very useful for house music - one of tracks going to ‘background’, and you work with 2 others. And it helps to save screen space.
Thanks in advance, waiting for this feature very much.
Hi @xxxbobrxxx, welcome to the Community! Thanks for the feedback. Please remember to vote at the top left of this page.
