Love the vjay app but I think there are a few relatively simple things you could update to make it that bit easier to use.
Finding the right clip can be a bit tricky, particularly if you have a lot of clips.
Videos in Camera Roll don’t contain titles, it would be great to include this info like in all the other menu sections.
The ability to edit ‘Featured’ would also be great, I want to delete your stock footage and have my own favourites in a handy place.
Also title search would be really helpful.
I’m using the Numark iDJ Live and would love to see the same browse support offered in DJay (large menu, option to select via the hard wear).
Love the app and look forward to updates!
