Recently (October 3, 2015) using Vjay for videos (nothing crazy) and after several minutes (Around 4-7) program crashes and returns to hopme screen.
This happened SEVERAL times.
In the other thread that you belong to, they asked for someone to send them a video.
I am not experiencing any crashes and I am using mpeg 4 videos.
Indeed sending over one of the concerned video files would be very helpful. You can sent it directly to “adrian@algoriddim.com”.
Update to help: It crashes when I use videos from “Videos” which are MP4 files created for ipad. Also, crashes when using video output using an APPLE lightning to VGA converter.
For are the same videos that I used before, but after your update few month ago I get this crash.
