Wondering if/how vjay for iPad works with the Wego 2 or other controllers. If the iPad needs to be connected to the controller does that mean that there is no way to get video out from the iPad…or do the controllers typically have video outputs?
Hi Sean,
Unfortunately, it’s technically impossible to use a MIDI controller and an external display via adapter simultaneously. The only way would be to stream your entire mix via Airplay.
Thanks for your reply!
Hoping that you guys are working on Vjay for Mac!!
