VJAY recording export to camera roll causes regress in quality
I have recorded the Vjaying that I did on the application and then shared them to camera roll then transmitted them to my computer but the quality regressed a lot. Is there a way to maintain the recording quality equal to each individual video quality?
Also if not can i play on Vjay the recordings that I have already recorded?
Best,
Hi Rana,
Thanks for contacting us. There should be no loss of quality when exporting from vjay to Camera Roll (and then from there to your computer). How did you export the videos to your computer?
By the way, as a workaround, you can export the videos to your Camera Roll and then the videos should be available in vjay’s library under “Camera Roll”.
