I just downloaded the update to Vjay. Now my music videos are loading even slower and the bar that shows where you are in the music isn’t even showing up til the song is over. Frustrating. The first version was the best, I wish I had never updated it.
If a video is loaded for the first time, it still has to be analyzed. This process may take a minute depending on the length of the video. If “Auto-Gain” is enabled, it can happen that the gain level will be readjusted right when the analysis is complete, this explains the volume jump.
During the analysis, the waveform is only in grey to optimize the performance.
By the way, after the video has been analyzed, loading it again later should be as fast as usual.
I have the same problem with an add jump in volume when it does finally load. Help Please!
