I have a few question about the Vjay app. For the iPad.
Is it possible to use the midi mapping feature from a keyboard midi controller like the M-Audio Oxygen, also I play in a band and would like use BMP feature to use either an external mic or an audio source from the PA and last is it possible to create a play list that will use videos in the order I put them in, I’ll have around 45-50 videos , one for each song. While I love the idea of being able to mix videos live , I will also be playing an instrument so there will be times that I won’t be able to mix, which brings me to, does Vjay offer any automation ? Thank for any help you can give.
Hi John,
Thank you very much for contacting us.
I’m sorry to inform you that vjay currently does not support audio input devices. Also, only djay has an Automix feature at the moment.
By the way, you can see the full list of supported MIDI controllers on our hardware page.
