I just purchased an IDJPro. I noticed that Algoriddim Vjay app is supported. Is there currently a way to connect to an external projector or video monitor while using the IDJPro controller? If not, is this something that is being worked on? My understanding is that using Airplay to stream the video would turn off the audio output from the ipad/IDJPro locally and it is not possible to plug in the Apple hdmi/composite/VGA adapters when the IDJPro is plugged in.
Hi Brett,
There are currently no adapters that would allow this. Actually, I’m not even sure if this is technically possible.
So, AirPlay is currently your only chance and yes, in this case the audio output in iDJ Pro would be disabled.
Sorry but on hdmi adaptater (http://www.maxigadget.com/2011/03/app…) it’s possible to plug hdmi cable and and idj pro cable in the same time. but this, does it work ?
(sorry for my english, i’m french and i don’t speak fluent english)
