Vocals EQ changes both vocals and harmony EQ
App: djay 5.3 (62752)
Device: iPad14,4
Language: English
MIDI Devices: Akai MidiMix
OS: iPadOS 18.3.2 (22D82)
Summary of the issue:
Hello. I’ve got 4 knobs on my controller MIDI-mapped to “Neural Mix EQ (4ch: Drums/Bass/ Harmonics/Vocals)”. First three knobs work fine. But “Neural Mix EQ (4ch: Vocals)” change both vocal and harmonic EQ. So it works like melodic EQ knob in user interface which is not expected behavior.
Hi @t3ks1st0, welcome to the Community! Thanks for the details about your setup and the issue. Can you please try to capture a short video of the issue and upload it here? Please note the maximum file size is 200MB, so if your video is larger than that, you’ll need to upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the file here. Thanks!
Thanks for the video @t3ks1st0. This was super helpful. I was able to replicate what you are experiencing and have passed this onto our engineering team for further review. Thanks again!
Hi @t3ks1st0, engineering has identified the issue and is working on a fix. This should be addressed in an upcoming release (likely 5.3.2). Thanks!
