Volume faders don't work when I switch to 4 decks
Hi, I recently updated my djay pro for iPad and immediately noticed that none of the volume faders would change the volume when the screen is in a 4 deck format? Never previously had the problem.
Hey guys,
we are sorry that you had to deal with this issue. We provided an update as fast as possible and the problem should be fixed.
Same issue here, since last update of few das ago
Isue solved same here, thx
*update* the last update fixed the issue, thanks guys!
