Please fix this problem
Hi Phil,
Which effect are you using? Also, is “Audio Limiter” enabled in the Advanced settings?
I tried with audio limiter on and off, but it’s the same thing.
Volume increases with all effects, except essential pack (echo,flanger,phaser,bit crusher,gate)
Version 2.7.5 of djay
Have you tried personally?
Phil, are you on djay 2.7.5? Select djay preferences (the gear icon) and scroll down, in order to look this up.
