Volume Increasing during Automix transition Solution
Hi there guys i had a problem where the sound would increase when the automix transitioned beetween songs and have seen its been a problem for others. I found one problem which has solved it for me. It was in the advanced tab setting just nder pre cueing turn auto select off and it has solved it for me. Hope this helps anyone.:+1:
Just to add it was the automatically selects inactive deck to play through headphones setting
