Volume of the looper
  • Device model: MacOs M1
  • Version of operating system: Sonoma 14.3.1
  • Version of djay: 5.1.2
  • Hardware/controllers used: Midi Fighter Twister
Good day,
The maximum volume of the looper is too low to add e.g. a real kick to a track that is already full of notes. Is this intentional, or am I missing something?
Thanks & cheers, Bart.
I’ve not noticed any problem myself. I’ve added loops to tracks and it’s been very well balanced.
I suppose it may depend on which kick you’re adding, and which track is “full of notes”.
Hi @Brainbox, thanks for the details about your setup.
  1. Can you please confirm that the individual Looper Channel Faders are at maximum?
  2. Please also confirm that the Looper Master Volume is at maximum?
  3. If this is already the case, is there a particular Looper Pack that you’re having issues with or is it all of them? Thanks!
Hello @Slak_Jaw , thank you!
Yes, all is at max, but @PKtheDJ has a point. Was using a house looper set on an old-style techno track to give it more punch. Let me try a bit and find a better techno oriented looper set. What I learn from this is that it is probably not a technical issue. :slight_smile:
Just lower the volume of your main track :smiley: :+1:
