VR headsets - who has used both?
I know nothing about this…am I even in the right place to ask? The MetaQuest video is better than the Apple Vision video, but which is easiest/best? is anyone DJ Kung-Fu Butterfly with these yet? I really need some end-user input here before I decide/commit. is Reddit or YouTube perhaps more insightful? All I see here are discussions about traditional controllers
Hi @heysoundude, I haven’t used djay on the Apple Vision Pro, but currently there is one major difference between it and the Meta Quest version that you should consider. At the moment, Apple Vision Pro does not support connecting MIDI devices, so it currently only works with virtual decks and not external hardware like the Meta Quest headsets. As far as overall comparisons between the 2, yes I think Reddit and YouTube would be better sources of info for you.
