GOOD MORNING EVERYONE, I have just bought Djay pro for my mac and I can not find how do I select wav as the preferred format for recording, could anyone help me with this please? Thanks in advance. Xabier
Hi Xavier arakistain,
you can change the recording format by following these steps:
- go to the djay Pro “Preferences” via in the top menu bar.
- select “Advanced”
- change “Recording Format” to WAV
please stay tuned for further updates, we will provide this feature as fast as possible.
Thank you very much Lukas !!!
Could I ask you another question?
is there a way to WRITE with the keyword
-instead of changing the number with the fader-
the BPMs number ?
Thank you again
besssst
Xabier
the BPMs number ?
Thank you again
besssst
Xabier
Ok, Thank you. Besssst. Xabier
