Currently using reloop buddy with iPad Pro , recently Ive been getting waveform lag on streaming & files formats . I’ve troubled shot the best to my old age ability (switch on and off , reinstalled the apps, hit with hammer , given it a good old talking too) but the problem is persisting , anyone have suggestions ? Tia
Which streaming service are you using?
If you’re using Tidal, you can try lowering the sound quality in Settings->Library->TIDAL
If you’re using Beatport LINK Professional, try adding the songs to the offline locker.
Tidal ,
I’ve put it onto hifi, hopefully that will help. Strange it’s only started doing this recently . I’ll update soon as .
Thank you
There have been some bugs with the higher quality settings in Tidal recently.
Hey @Dannyalls ,
Thanks for writing about this here in the Community!
As @Slak_Jaw rightly pointed out, there have been some issues with the Tidal HiFi settings: just writing to check, have these issues been solved for you ever since?
I’ll be on the lookout for your reply. Have a nice day!
